41-295 I.F. harmonics across dial
That would be no problem, since there isn't anything either side of 1500. Thanks exray! I have to get a project off my bench, then I will try making a toroid coil and trimmer. How many turns of wire should I use on the toroid?
Use a -61 ferrite core. That's the most important. Can be any size. FT50-61 would be the minimum size (0.500 inches) , FT82-61 is a good compromise (0.82 inches).
Since we're only tuning one freq at the high end of the band use about 40-50 turns (not terribly critical) of small wire like 28 or 30 gauge. Use a 100pf trimmer cap for tuning.
Sounds good! There's a surplus store nearby that has those ferrite cores in bulk. And cheap!
Thanks again for all your help and advice!
Mike
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
