Portal
Search
New Posts
Today's Posts
PhilcoRadio.com
Philco Gallery
Philco Library
Philco Radio Enthusiasts
More
Help
Calendar
Members
Steve Davis Cabinets
DIY Photofinish
Login
Register
Hello Guest,
Please feel free to join us!
There are many more parts of the Phorum that only members can see.
Login
Username:
Password:
Lost Password?
Remember me
The PHILCO Phorum
Philco Radio Discussions
Philco Cabinet Restoration
0 Vote(s) - 0 Average
1
2
3
4
5
Threaded Mode
15X Resto Help
bonanzaman
Junior Member
Threads: 4
City: Westcliffe, CO 8000ft MSL
05-05-2013, 04:00 PM
Deleted.....
(This post was last modified: 05-05-2013, 10:11 PM by
bonanzaman
Find
Next Oldest
Next Newest
View a Printable Version
Shadow Meter Bulb
Ok. Thanks for the correction.
RossH
— 03:09 PM
Model 28L
For 28 you will probably need to buy a Hammond 125CSE. Or any of the series of the power you need, with SE suffix. Then ...
morzh
— 02:09 PM
37-60 revision 6
I am restoring a Philco 37-60 and it shows run 6 they removed the ground from G3 of the 6K7G and put the G3 to -2.5v for...
bobbyd1200
— 01:01 PM
Shadow Meter Bulb
Mike is correct on the bulb connection, two separate circuits. I found that by rotating the bulb and sliding it forward ...
RodB
— 12:19 PM
Hickok AC51 tube tester
Cleaned ann contacts, switches and sockets, works great now.
martinj
— 11:32 AM
Model 28L
Hello, I'm restoring a Philco 28L and the output transformer is open. Part number of the transformer is 32-7020. Can...
HORSTE
— 10:32 AM
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit. That would rem...
alangard
— 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural. Th...
morzh
— 08:40 PM
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...
martinj
— 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...
morzh
— 08:31 PM
There are currently
3940
online users. [
Complete List
1
Member(s) |
3939
Guest(s)
The PHILCO Phorum
