37-610 in a 38-9 cabinet cabinet restoration
Well after 5 hours of sanding shes almost ready for lacquer...
[Image: http://i1095.photobucket.com/albums/i474...cb813f.jpg]
[Image: http://i1095.photobucket.com/albums/i474...6fe12a.jpg]
[Image: http://i1095.photobucket.com/albums/i474...15d98d.jpg]
[Image: http://i1095.photobucket.com/albums/i474...9af81c.jpg]
[Image: http://i1095.photobucket.com/albums/i474...772caf.jpg]
Didnt use any stripper?
Did you sand by hand?
Going to use spray toner? Stain?
Looks good.
Tim
Used a electric hand sander 80 grit paper went over it following the different grains in the wood,being careful to just take the lacquer off to bare wood will go over it with fine paper next apply some light stain to the bottom and the strip just at the top. Then spray Lacquer it all over..Did it the same way to the radio(except for a slightly lighter stain will go on mine) I gave to my Sister..here's a pic of hers
[Image: http://i1095.photobucket.com/albums/i474...IM1613.jpg]
I would highly recommend that you use a chemical stripper next time rather then a sander, there isn't much meat to the veneer all it takes is one slip up and you've burned right through it.
I have a Philco 620 where someone used a an electric disk sander on it, not only are there a bunch of swirl marks but they all but ruined the molding on the front panel. Unfortunately the only way to repair the swirl marks is to reveneer the front panel, they are too deep to sand out, the moldings I'm not sure what to do with.[/u]
Put the decal on and 2 coats of lacquer so far.
[Image: http://i1095.photobucket.com/albums/i474...e1ef3d.jpg]
[Image: http://i1095.photobucket.com/albums/i474...8f034a.jpg]
[Image: http://i1095.photobucket.com/albums/i474...36d09c.jpg]
I can even see you in this photo Icon_smile
Got it back together today and it sounds great!!,but have some tweaking to do.Also awaiting the correct grill cloth.
[Image: http://i1095.photobucket.com/albums/i474...8c3857.jpg]
[Image: http://i1095.photobucket.com/albums/i474...f068d4.jpg]
[Image: http://i1095.photobucket.com/albums/i474...f19110.jpg]
CDs go well together with it Icon_lol
Gee Thanks....
Im so glad I took the time to post the pictures I think it will be a Long time before I make that mistake here again.
Which mistake was that?
I like it.Icon_biggrin
Looking good!
Nice job!
Tim
Thx Richard. Arran, the 0.02 caps in mine are also 100v. As I mentioned the original paper tube is just a little small...klondike98 — 01:02 PM
New find. 91X code 225
Nice job there. A very distinguished looking radio. Would like to see a photo when done with added light. Paul B.Paul Philco322 — 12:27 PM
Thanks all. Yeah, I was motivated to do this one and they're generally easy to work on. I don't do a lot of early-'30s...pdieten — 10:22 AM
Hello Bob, What nice looking set it looks like a Emerson that I have you did great job with the two Electrolytic cans ....radiorich — 02:04 AM
Hello Paul, Well, done it looks great ! Sincerely Richardradiorich — 01:55 AM
Congratulations, Paul! That was quick...you made short order of that chassis restoration! And no coils to rewind...bonus...NostalgiaRadioTime — 01:07 AM
Bob; I was thinking the same with that 150 ohm resistor, put a larger value replacement in it's place to compensate f...Arran — 01:02 AM
And the chassis is all done, all caps and bad lamp wiring replaced, power switch repaired and in place, dial string tune...pdieten — 12:37 AM
As I think more about that 150 ohm resistor that directly follows the selenium diode, I’m going to have to add some seri...klondike98 — 11:47 PM
It looks like all the resistors except one are OK. Arran mentioned replacing the sand 150 ohm resistor and mine looks l...klondike98 — 02:25 PM
There are currently 1179 online users. [Complete List]
» 1 Member(s) | 1178 Guest(s)
