Philco 70 1929 Cabinet
I am trying to "restore" my philco lowboy cabinet; it is really dry mahogany and I did not know if I should just use an oil on it or what .
Any suggestions?
Hi George and welcome to the phourm!
Just to be clear on your set it isn't a model 70 as it didn't come out till 1931. It's probably a model 87 or 95 but would have to see the back of the set to tell which one it is. I don't know if you know it or not but the legs on your cabinet have been removed. It should stand a bit taller. Here's a pic of it: http://www.philcoradio.com/gallery/1929c.htm#d
I have a model 87 and the 95 both are good set for 1929 technology!
I like to use GoJo pumice free hand cleaner to get all the old oil and wax off first. Then, Howard's Restore-a-Finish it it needs a little color. Finally, Howard's Feed'n Wax (orange oil + beeswax).
Here's a Philco 70 lowboy from 1931 for comparison.
[Image: http://farm3.staticflickr.com/2181/41215...db21_z.jpg]
Thanks everyone! I will try the products you recommend for the finish. I am also trying to find a set of legs for my radio since they have been removed.
George
Hello Bob, What nice looking set it looks like a Emerson that I have you did great job with the two Electrolytic cans ....radiorich — 02:04 AM
New find. 91X code 225
Hello Paul, Well, done it looks great ! Sincerely Richardradiorich — 01:55 AM
Congratulations, Paul! That was quick...you made short order of that chassis restoration! And no coils to rewind...bonus...NostalgiaRadioTime — 01:07 AM
Bob; I was thinking the same with that 150 ohm resistor, put a larger value replacement in it's place to compensate f...Arran — 01:02 AM
And the chassis is all done, all caps and bad lamp wiring replaced, power switch repaired and in place, dial string tune...pdieten — 12:37 AM
As I think more about that 150 ohm resistor that directly follows the selenium diode, I’m going to have to add some seri...klondike98 — 11:47 PM
It looks like all the resistors except one are OK. Arran mentioned replacing the sand 150 ohm resistor and mine looks l...klondike98 — 02:25 PM
Yeah the 121/221 documentation was correct for the RF end of the radio. It left me scratching my head when I was looking...pdieten — 11:59 AM
philco predicta
Hi CGL, Yes, troubleshoot the 140V Power supply, something is definitely loading it down, and since this supply excl...MrFixr55 — 07:32 AM
1934 American Bosch 440T restore on YouTube
Looking forward to Part 2.Jimradio — 07:30 AM
