40-195 under-top antenna connections?
What are the connections for the antenna under the top of the Philco 40-195 (not the rotation antenna below the chassis board)?
I do not see this antenna on the schematic: http://www.nostalgiaair.org/PagesByModel...013340.pdf
Note that the coil, part 5, is at the 1st tube socket, and is not the antenna I am seeing.
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
Good morning,
That is the SW loop, and is part (2) on the schematic, not part (5) which is the loop loading coil.
One lead of the SW loop connects to terminal 3 of the four-screw terminal board at left of the chassis, as viewed from the rear. The other lead connects to the frame of the tuning condenser. There is a hex head screw on the frame, on the right side (again, as viewed from the rear), for this purpose. If the screw is missing, there should be a hole for an 8-32 machine screw there.
Rogers Majestic R-646
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
Philco 89 Code 123 Osc Coil
There are currently 891 online users. [Complete List]
» 3 Member(s) | 888 Guest(s)
