Magnavox CR-192 FM Tuner Dial Scale
I recently picked up a Magnavox CR-192 FM tuner. Unfortunately the dial scale is broken. I have not been able to come up with a reproduction or a replacement. Has anyone had success creating their own dial scales using a clear transparency sheet?
I've done that several times, but I need a significant (most) part of the original dial to make it happen, or a good quality scan of one.
Thank you for the feedback. I will keep that in mind.
It looks like I have found a replacement dial scale.
Regarding picture 5 on page 1 of this thread this capacitor is #40 on scematics diagram - 4mF+4mF. Black wire is "-...Vlad95 — 09:01 PM
That's a dual 4 MFD, red and green are both 4mfd and black is common negative. You should be able to see them in the pow...RodB — 08:58 PM
Can anyone help me figure out a capacitor that has 3 wires coming out of it red and green on one side and a black wire o...osanders0311 — 08:14 PM
The transformer may be the last cause of voltage drop. This level of voltage drop is not too big. Conduct additional te...Vlad95 — 07:16 PM
Well I have found 315v on the rectifier when cold. Drops off to 280 after 15 minute warmup. Checked pin 3 on both 6F6 t...murf — 04:14 PM
Thanks for the replies, I will check these ideas out and report back. murfmurf — 03:18 PM
Sorry, my mistake. murfmurf — 03:07 PM
MrFixr Honestly, I haven't done that yet and do not want to screw up the threads; maybe you could do it, or we could...morzh — 12:48 PM
Two small radios from France. Restoration and review.
Greetings; I think that it's possible that the assortment of components was the result of post war parts shortages, a...Arran — 12:18 PM
Unfortunately I can't inject any audio into the volume control. It is in the primary circuit of the antenna coil, not in...Stormlord5500 — 09:32 AM
There are currently 293 online users. [Complete List]
» 2 Member(s) | 291 Guest(s)
