Threads: 42
City: Shinnston, West Virginia
State, Province, Country: USA
I am working on a Philco 38-690. Most all of the electrolytic capacitors have been replaced in the past. I am looking where I can purchase 630 Solen and regular Electrolytic capacitors?
nv3g
Oscar
(This post was last modified: 12-11-2018, 09:10 AM by
NV3G.)
Threads: 573
I used higher rating for the caps that are parts of the primary rectifiers' (two of those) filters.
I serialized 22uF 450V high-ripple Panasonic caps to get 11uF of high-voltage capacitance where 8uF was needed.
the caps after the tweeters' field coils might be 450V as there is significant drop across them.
I am sure 450V is Ok too.
http://philcoradio.com/phorum/showthread.php?tid=18450
In this 38-690 restore linked above, I used two 8 uF
630V Solen caps in parallel to equal 16 uF to replace the 18 uF cap, and 8 uF
630V film caps to replace the 8 uF caps.
30-2201 was originally rated as follows: 8 uF, 475V and 10 uF, 50V.
I would not use 450V caps, especially taking into consideration today's higher line voltages. I would go with 500V, minimum. Or better yet, use as many Solens as you can - they should never need replacement again as long as you own the set.
Threads: 1
City: Georgetown, IN
(12-06-2018, 11:46 AM)Ron Ramirez Wrote: http://philcoradio.com/phorum/showthread.php?tid=18450
In this 38-690 restore linked above, I used two 8 uF 630V Solen caps in parallel to equal 16 uF to replace the 18 uF cap, and 8 uF 630V film caps to replace the 8 uF caps.
Ron, I just now saw your thread on your 690. Sure brought back memories of restoring that 38-116 that I bought from you many years ago. My 116 had the same hacked up tube shield bases. Luckily Gary Schneider of PTOP had some NOS Philco tube bases in stock that I was able to purchase at the time.
I also recall having to use a Dremel to slightly enlargen the hole in the repro dial that I purchased from Mark Oppat.
Here is the article about my 38-116. That article was written a while back and my restoration skills, as well as my writing skills, have vastly improved since then. I see quite a few things that I would have done differently today.
(This post was last modified: 12-13-2018, 04:33 PM by
Jeremy S.)
Jeremy
You certainly turned that ugly duckling 38-116 back into a beautiful swan!
