Philco Part
Hi all
I started to align my philco 37-675 in the alignment instructions to tune the RF and ANT. it refers to a part 45-2325 clipped
to the trimmer in the band 5 and band 4 to tune the these caps. Does anyone know anything about the 45-2325 item?  Icon_think
Thanks
Joe
That was a 350 pF variable capacitor, as I recall, and was set to make the second harmonic of the oscillator beat against the signal from your signal generator.
You can use any variable capacitor in the neighborhood of 350 to 365 pF or so, it does not have to be the actual 45-2325 item.
Thanks Ron  Icon_clap
Joe
The transformer may be the last cause of voltage drop. This level of voltage drop is not too big. Conduct additional te...Vlad95 — 07:16 PM
Well I have found 315v on the rectifier when cold. Drops off to 280 after 15 minute warmup. Checked pin 3 on both 6F6 t...murf — 04:14 PM
Thanks for the replies, I will check these ideas out and report back. murfmurf — 03:18 PM
Sorry, my mistake. murfmurf — 03:07 PM
MrFixr Honestly, I haven't done that yet and do not want to screw up the threads; maybe you could do it, or we could...morzh — 12:48 PM
Two small radios from France. Restoration and review.
Greetings; I think that it's possible that the assortment of components was the result of post war parts shortages, a...Arran — 12:18 PM
Unfortunately I can't inject any audio into the volume control. It is in the primary circuit of the antenna coil, not in...Stormlord5500 — 09:32 AM
Sounds good Gary I'll do that. I have plenty of stuff like that I can scrounge up. I am still kind of new to all this so...Stormlord5500 — 08:47 AM
Philco Battery-WWII vintage
Seems to me that this a general purpose or radio filament 6V battery of very high amp-hour capacity and very high "...MrFixr55 — 08:08 AM
Hi Morzh, From my end, no. I did not know that there are 2 threads on this topic. Maybe it should be combined.MrFixr55 — 07:13 AM
There are currently 231 online users. [Complete List]
» 1 Member(s) | 230 Guest(s)
