Painting a Sparton mirror dial???
I   just bought this Sparton model 98 radio and the dial has some paint that came off.. It is not peeling,,this had come off years ago.. Does anyone know of a way  or type of paint that will work on the back of the glass
   Living in Calgary Alberta
I might search these guys. I ran into their site looking for crystalline paint and they seem to have all sorts of things that are meant for glass
http://jurgeninc.com/Lacquer-Glass-Paints/
   That sort of paint looks very promising ,,except that  orders to Canada must be a t least $100.00.
 I would have to have a lot of dials to paint before I did that .. I might check out some glass shops.
     But you did give me some ideas ,,,maybe hobby shops might have something like that .. Thanks  Dan
Mike; I've only run into a speaker with an open filed coil twice, and they were on newer speakers from the 1940s. One ...Arran — 12:48 AM
Arran Yes, this is my plan for now and what do I got to lose, this is not even the speaker from this radio, but one o...morzh — 10:44 PM
Mike;  I would unwrap the field coil, and see if maybe there a break near one of the ends, like where the coil wire att...Arran — 10:23 PM
...and this is what I did. I fed a little LT into the screwholes with a small brush, and a little on the rim next to the...morzh — 09:52 PM
Philco 40-120C Restoration
I combined the two 40-120C threads together as we like to keep the discussion of the same radio together. It helps with...klondike98 — 09:36 PM
Philco 40-120C Weak, Distorted Ouput
Just checked were I buy tubes price is four dollars. So living in Florid we have a local source for tubes. David    David — 09:14 PM
The higher voltage may be due to higher mains voltage. My mains run 120-125AC when the set was new mains would be 110-11...David — 09:09 PM
Thank you for your reply. I pulled a speaker from a Philco 41-221 and received the same result. I used a signal tracer t...bluecap — 08:45 PM
Have you tried a different speaker? How did you trace the distortion? How do you know it is weak? What is the reference?...morzh — 08:33 PM
Amen to that! Every time I think I’ve captured them all, I realize that there’s another error. My goal is to finish with...jrblasde — 07:00 PM
