Model 70 progress
I picked this up last month and started working on it.
http://s1336.photobucket.com/user/220koh...n.jpg.html
http://s1336.photobucket.com/user/220koh...e.jpg.html
http://s1336.photobucket.com/user/220koh...w.jpg.html
You can see 2 paper caps at top of pic that I had to replace with a bakelite block
http://s1336.photobucket.com/user/220koh...2.jpg.html
http://s1336.photobucket.com/user/220koh...b.jpg.html
A big thanks to Steve Davis and his wife. Here is a pic of the front peice they made for me. Great job guys.
Put the dial on loosley just for this pic. Got to get some tiny bolt&nuts for it
http://s1336.photobucket.com/user/220koh...g.jpg.html
slowly getting there
I did mess up the top of the mershon caps ERRRR!
I did power it up last night and all stations are comming in fairly clear. and I still need to align it.
Thanks for looking
Looks Good! It's too bad that the 70's don't have a better spkr and detector circuit. They don't sound great, good but not great.
Thanks Terry. Yea have to agree about the sound. I have a 90 and 20 and the audio is about the same. Of course none of them I own have the push pull output.
Its been a fun restore so far but don't know when I will get to the cabinet its so hot and very humid here. Probably the fall.
Well it's not really the fact that it doesn't have push pull audio output ( the 20 does). If you ever hooked up a pm spkr across the output transformer of the 20 but you'll hear a big difference. Sound really good. Those brown "pie pan" spkrs have a very stiff spider and cone this limits the low frequency response.
The 70 and 90 use a thing called a Power Detector. It has a fairly high output enough the drive the 47 but also generates a high lever of distortion. I suppose you could replace the the 24A with a 2A6 and rewire it as a diode detector/triode 1st audio and add avc then you'd have something. You could also lose that dual gang volume control that is difficult to find a replacement.
Single ended audio output can sound very good it's all in the design.
Agree with all, a single ended output and a reasonably high efficiency PM speaker can really sould very good, especially if we're talking about A.M. radios. That being said, original equipment, if still up to speed can also be quite pleasant to the ear. As always, "it depends."
Only the early 90 with push-pull 45 output tubes used the power detector. The 90 with single 47 output and the 90 with push-pull outputs used a 27 wired as a diode as the second detector, producing cleaner sound.
Likewise, the early model 70s used the power detector - late versions did not.
[split] New member...
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
There are currently 1014 online users. [Complete List]
» 3 Member(s) | 1011 Guest(s)
