48-1256 alignment help.
Getting geared up to do the AM alignment on the 48-1256 I've been slowly trying to restore.  Never done one of these on my own before, so I've got a few questions.
For reference, here's a pic of the alignment instructions from Sam's:
[Image: http://i.imgur.com/Y42Czls.jpg]
1. I have an isolation transformer.  Am I reading that correctly that if I use it, I won't need to solder in the .01uf or 200pf caps?
2. What does it mean in the coupling section about high side & low side?  And where do I access B-?
3. Any idea what that smudged section under Output Meter might have said?
< I have an isolation transformer.  Am I reading that correctly that if I use it, I won't need to solder in the .01uf or 200pf caps?
Use the transformer and the caps. They are for coupling not to prevent shock hazard.
<What does it mean in the coupling section about high side & low side?  And where do I access B-?
Read high side of signal generator (center conductor of output cable) output/ low side is ground side of generator. B- would be at the- side of your filter caps. = RF ground
< Any idea what that smudged section under Output Meter might have said?
Output meter would be an analog ac voltmeter set to it's low range (like 1vac full scale) connected across the spkr voice coil. Tune for max reading.
Hope that answer ur questions.
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM
Need Help to ID this radio 11 tube Philco
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM
Yup Arran is correct it is missing the pushbutton covers. I don't know where they all go but it's a common issue on this...Radioroslyn — 06:48 AM
I also have one of these, again it never had a back, and no trace of one. I have been told that the pushbuttons used to ...Arran — 03:29 AM
Thanks Joseph. Hope you get to restore your 48-482 before too long!keithchip — 02:12 AM
RCAs ain't no cake either.morzh — 10:32 PM
After a couple of days worth of troubleshooting my signal generator, I gave up. The oscilloscope still worked fine, so I...jrblasde — 09:51 PM
Yes, I can confirm. I bought one (haven’t restored it yet) which didn’t have a back panel.jrblasde — 09:37 PM
Try a 39-116.Radioroslyn — 09:24 PM
There are currently 994 online users. [Complete List]
» 2 Member(s) | 992 Guest(s)
