Model 531 removing switches
I have a 20s-30s Philco lowboy model 531. I want to get the chassis out but there is a toggle switch and a phono jack that has to be removed from the front panel first. The switch and jack both have round ring nuts with grooves like the edge of a dime. I can't get a grip on them with needle nose pliers cause they're slightly sunken into the brass control panel and i'm afraid i'll scratch the panel. Is there a technique or special tool to remove those nuts safely?
Thanks!
Hi
Try a regular pair of pliers, with a cloth between the pliers and the nut being loosened.
Be extra careful with the phono jack. It will have two bakelite washers; one just behind the nut which holds the jack in place; another behind the brass panel. Do not lose either one! Makes notes of how each washer is installed, so that you reinstall everything in the same order when you are finished.
This is very important, since the phono jack has B+ on it. If any of the bakelite washers are lost, the jack will short to ground, killing your set's reception by grounding the B+ voltage which runs to the plate of the detector tube (Type 27) through the phono jack and the primary of the first audio interstage transformer.
There wasn't enough sticking out to get ahold of with pliers but i did get lucky with a pair of angled hemostats... yay! Thanks for the headsup on the washers.
Philco model 40-100
Thanks Arran and MrFixer55 for your input regarding my post. I think I will just fix the on/off flag in place so that it...mhamby — 07:19 PM
Thank you for the reply Arran. I will do as you suggest and report back.Stormlord5500 — 03:34 PM
Arran, Thanks for digging into your radio library. The Studebaker radio model is AC-2687/S5524. It has a power/ speaker...Pdouglaski — 02:04 PM
Philco Battery-WWII vintage
Yep. It had handles on either side, and it took two reasonably strong men to carry it. We had that Soviet FIAT 500 c...morzh — 11:45 AM
PT-6 finished!!
I’ll get on doing that and see what happens. Just to keep this all in one thread - Anyone know what length/size is u...bridkarl — 10:01 AM
Hello Ed, Well done on your part anyway that radio uses neon bulbs ? Sincerely richardradiorich — 09:43 AM
PT-6 finished!!
I agree with Ron. That’s how my 49-906 behaves. That’s why I’m curious if the bulb stays at full brightness if the recti...jrblasde — 07:54 AM
I don’t know exactly how dim your pilot gets but this is the typical of the response of many transformerless AA5s where ...462ron — 07:38 AM
Well Philco did start out in the lead acid battery manufacturing business, and I think that they were still doing so dur...Arran — 12:06 AM
It is odd that they chose the autodyne mixer/oscillator in one version of this set, with the #15 tube, but chose to use ...Arran — 11:02 PM
There are currently 1387 online users. [Complete List]
» 1 Member(s) | 1386 Guest(s)
