Philco 16B Tombstone question
Hello, all: any suggestions for what color/product to use for the light colored lines that go up the 3 bars of the grillework and parallel across the lower face?
I am about to start shooting the cabinet with clear and wanted to get the detail the correct color before I do.
If you can find nail polish in a tan color, that would be a good choice. Nail polish is lacquer, and won't interfere with your lacquer spray.
Don't use yellow, or white, or ivory. Ivory is too light. Tan is about right.
Another choice is brush-on auto body touch-up paint, which is usually lacquer also.
It may take some searching, but hopefully you will find something suitable.
Thanks, Ron. Those are some great ideas. Yes, I was concerned about making sure that the medium that I used for these details did not interfere with the rest of the laquer finish.
Rogers Majestic R-646
Since the original schematic was in an old unreadable style, I created a new schematic diagram. Owners of this radio ca...Vlad95 — 11:09 PM
Hello Peter, What great project I am looking forward to see your progress with this console !! Sincerely Richardradiorich — 10:20 PM
Ok guys, JustRadios has me worried after reading an article about purchasing resistors and I hope that I haven't made a ...osanders0311 — 08:59 PM
Yeah, I have no idea what's going on there. I will re-check it in the morning, and also trace out the B+...sq65 — 07:55 PM
Peter; The Philco (3)16X was likely a Canadian market Philco, which means that Philco Products of Canada LTD likely h...Arran — 07:45 PM
It is kinda impossible for the plate to have 120V with the tube in and have it not with the tube out, short of the tube ...morzh — 07:42 PM
In case anyone else run into the issue I had figuring out Richey caps I received a response from just radios, and the ne...osanders0311 — 05:07 PM
About all I've done is unplugged them to take the chassis to my workbench. Anything I should check with them?sq65 — 04:13 PM
Have you touched the speaker wires, either speaker plug or the socket?morzh — 03:47 PM
Jonnym
Thanks everyone, I will pull the chassis out of the cabinet and do some checking.    The volume adjustment is not “scra...Jonnym — 02:01 PM
