Zenith with candohm resistor
You are better off starting a new thread. Third of an amp is because the tubes filaments are third of an amp each and serialized it will be still third of an amp when hit with the sum of all voltages, the rest dissipated by the Candohm which is be third of an amp square (1/9) tines the ohms of the Cwndohm.
