ID Silvertone
Posted: Aug Thu 05, 2010 12:32 am
[Image: http://i276.photobucket.com/albums/kk15/...io/001.jpg]
I tried the number on the back right corner and the numbers on the tuning cap but can't seem to find the radio. Even tried looking on Ebay. Cleaned up all the switches and AM works great but can't get anything on FM. Tried a signal generator on FM and the radio I listen to picked it up but not the silvertone. Freaked out the cat with the tone
Thanks in Advance everyone
http://s276.photobucket.com/albums/kk15/...e%20Radio/
(photo added by site admin)
Hi
That unit looks like it is from the late 1960s or early 1970s; and as such, you will probably find little if any information on it since it is too new to be "collectible."
That having been said, however, there should be a model number on that back cover somewhere. Something starting with, if my memory is correct, 51-xxxxxx and/or 562.xxxxxx. This will, at least, enable you to find the correct Sams Photofact for it.
Hi Ron
All the tags are gone, nothing inside or out. I even tried searching what I believe to be the chassis number with no luck. Fm side is out, no static, nothing. Guess it's time to start just testing componets.
Bob
That's too bad. Sorry I could not be of more help on this one.
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
There are currently 907 online users. [Complete List]
» 1 Member(s) | 906 Guest(s)
