38-93.....so far
#31
HOW DID YOU FRY YOU FREQUENCY COUNTER,,MAY I ASK,,,SOO,,I DON'T DO THAT WITH MY $9.00 ONE,,,CHEERS
#32
Ken,
Have you gotten your Caps Lock key stuck today? Icon_lol
#33
I don't know. It just went haywire. I had taken it loose and may have touch the lead to the HV when I moved the chassis. Other than that I don't have a clue. I ordered 2 more from FeeBay.
"He has all the virtues I dislike and none of the vices I admire." — Winston Churchill
#34
The more I looked a this thing, the more I disliked all the yellow capacitors. Icon_thumbdown So I dug around and found some micas that were close enough to what was called for, and re-stuffed the tubular capacitors in their original tubes (all two of them). Call me OCD, but I think it looks better. Icon_biggrin
Kelly
#35
It does!
#36
Thanks morzh.
#37
Lately I've been restuffing the caps for most radios I work on. Even though no one will probably see it for a long time - or even care - I know they're there. Icon_smile
#38
Hmmm. I wonder if that frequency pointer would work on my Scott 16...  Anyone have a spare?
#39
Wanted ads go in Wanted Ads, not here. No ads allowed except in For Sale or Trade and Wanted Ads.
I think if,,,,I was stuffing CAPS,,,,,I have to leave a NOTE in the chassis,,,lololol
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
My Philco 37-116 Restore
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
When dealing with noise on power lines, time to get my Jackery 240 out. Talk about clean can hold a portable am radio ne...David — 08:52 PM
Arran - I bet you're right probably vinyl, there was no rubber smell when desoldering it, which you often get with the o...EdHolland — 08:23 PM
Ed; It was very likely vinyl covered wire given the vintage of the set, there was some rubber/gutta percha wire used ...Arran — 06:34 PM
I think the problem is traced - to noise on the AC line. It sounded so local, that it seemed certain it was generated wi...EdHolland — 05:51 PM
A little bit of positivity in our feed... My new video... Test - the Philco 16B vs Philco 37-116 de Luxe / Test - the ...RadioSvit — 12:14 PM
Refinishing Ideas
Thanks. I will look into. Billpoulsbobill — 11:23 AM
There are currently 483 online users. [Complete List]
» 2 Member(s) | 481 Guest(s)
