1936 Philco 620B Silent
I turned on my 1st complete restoration, my 1936 Philco 620B Tombstone, to listen to the local news late this afternoon, and got no audio.  Icon_e_sad  Not even static at full volume.  Icon_e_sad
I recall the last time I turned it on, it worked for a minute, then went silent.  Icon_shh
Up to the last time I turned it on, it was my go-to radio to listen to. It's been an excellent performer, so I'm a bit surprised.  Icon_confused
So I'm pulling it down and 1st thing will be to pull and check the tubes.  Icon_wink
[Image: https://farm5.staticflickr.com/4694/2612...47dc_z.jpg]
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
1st thing I checked was the output tube, the 42. It checked out OK. Next was the 78 (IF), also OK. 75 tested strong on all 3 tests. The 6A7 shows just a nudge under 300 on the OSC section, but my chart says OK if above 100. The Other 78 (RF) tested in the Red, low. Icon_thumbdown
I pulled a 78 from my 620F, and popped it in, and the radio came right on and worked as it always had. Icon_thumbup
Then, just to confirm it was that tube, I popped the original back in, and it worked! Icon_confused Odd. I jiggled the tubes around, checked the grid cap connections, and it continued playing. Maybe it was just a loose connection somewhere. Icon_crazy
For now it's working, so I'll stick it back up on the shelf. Icon_rolleyes
I'll re-visit this thread if it acts up again. Icon_wave
Blessings,
Jeff W.
Jonesboro, Arkansas
Even if tube tests LOW, unless it tests DEAD it usually works, just not so well. With few exceptions, an oscillator might be one.
There are currently 1206 online users. [Complete List]
» 2 Member(s) | 1204 Guest(s)
