Way to Save $$ on Mohawk Toner Lacquer
I use a ton of Mohawk and, depending on where you are, found a much less expensive source than buying online.
If you go to Mohawk's site and check the "Find a Distributor" link, you can search for a distributor that's local to you. I'm in Atlanta and found a few. Turns out they sell the toner lacquer for a couple bucks less per can than online, with a greater selection and no shipping costs.
Here's the link: http://www.mohawk-finishing.com/dist_lookup.asp
If you don't find one in their list, call a local paint distributor/wholesaler and see if they carry. (not a retail paint store).
Hope that helps,
Joe
P.S. I'm not associated with Mohawk in any way, I have just found their product to be superior to work with for hand-rubbed cabinet finishes.
"Ignorance is bliss...'til you have to fix a radio..."
Thank you for sharing this information, Joe.
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
