Volume Control for Philco 620
I need to find a suitable on/off/volume control for my 620 rebuild. The original was replaced with an incorrect part. The original part is 33-5105. I believe it is a 1 Meg part with a 225K tap. Does anyone know where I can locate a replacement? I would like to find a working original if possible.
I see that AES sells 1 Meg switched pots, but they don't list any info about a tap. What is the tap used for? I take it that is a fixed resistance used for something other than for volume control?
Thanks.
Contact Mark Oppat - moppat AT comcast DOT net
Hi Derek,
The tap is used for bass compensastion at lower volumes. It's tapped at the lower end of the volume control with a cap and at low volumes it has a tendency to shunt the high frequencies to ground. On higher volumes it has little or no effect You can go without it if need be or order one. Some folks say it makes a difference some say it does'nt. The circuit will work without it.
Hope this helps
Thanks Chuck, I'll send Mark and email.
Terry, Thanks for explaining the circuit. That helps a lot.
Derek
Rogers Majestic R-646
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
There are currently 981 online users. [Complete List]
» 2 Member(s) | 979 Guest(s)
