37-610 Bullet
This cabinet has an opening on the bottom that looks like it was put there at the factory. Just wondering what the purpose of this opening is? This is the only radio that I’ve seen with this cutout.
Picture always helps.
    .  Here’s a picture of the bottom.
Don't know factory or not, but it looks like a removable cover/plug and seems to give access to the RF chassis' adjustment parts (trimmers etc), so this is probably what it is. It then should be replaced after the alignment.
(04-17-2019, 08:01 PM)Tucker Wrote:  This cabinet has an opening on the bottom that looks like it was put there at the factory. Just wondering what the purpose of this opening is? This is the only radio that I’ve seen with this cutout.
I'm not sure about this, but my guess is , since this model has such an involved array of switching, it could be for easy cleaning of those switch contacts.
Cool radio.   Icon_cool
I've never seen an opening like that on a Big Bullet. Pardon me for being skeptical, but it appears one could not get to all of the adjustments with that opening (some hidden toward the front)?
Yes. But it appears well made. Even factory made.
Maybe a prototype.....???
Would an output transformer if weak, cause the problems I am seeing with lower B+ voltage? murfmurf — 01:22 PM
Hello murf! I merged the threads. Please do not start new threads regarding the same radio. Take care, - GaryGarySP — 10:21 PM
Regarding picture 5 on page 1 of this thread this capacitor is #40 on scematics diagram - 4mF+4mF. Black wire is "-...Vlad95 — 09:01 PM
That's a dual 4 MFD, red and green are both 4mfd and black is common negative. You should be able to see them in the pow...RodB — 08:58 PM
Can anyone help me figure out a capacitor that has 3 wires coming out of it red and green on one side and a black wire o...osanders0311 — 08:14 PM
Two small radios from France. Restoration and review.
Greetings; I think that it's possible that the assortment of components was the result of post war parts shortages, a...Arran — 12:18 PM
Unfortunately I can't inject any audio into the volume control. It is in the primary circuit of the antenna coil, not in...Stormlord5500 — 09:32 AM
Sounds good Gary I'll do that. I have plenty of stuff like that I can scrounge up. I am still kind of new to all this so...Stormlord5500 — 08:47 AM
Philco Battery-WWII vintage
Seems to me that this a general purpose or radio filament 6V battery of very high amp-hour capacity and very high "...MrFixr55 — 08:08 AM
You should be able to inject an audio signal such as from a CD or mP3into the radio at the volume control. The set will...MrFixr55 — 08:14 PM
There are currently 536 online users. [Complete List]
» 1 Member(s) | 535 Guest(s)
