I have got a 40-195 that I got from antique strore.I had the chassis out cleaning it and noticed what looks like little electric motors on the tone and volume controls. Are these motors or something else? If they are motors do they turn voulme up and down or what? The tube light up but just makes noise. Is it worth fixing? Thank You for the help Mike
Hi
No, the tone and volume controls do not have motors on them. Each does have a gear on the end of each control shaft; this gear contacts teeth in the tone and volume thumbwheels, respectively. This gearing is what makes the controls operate.
Sometimes teeth break off either the tone or volume thumbwheel, or both. Where the teeth are broken, the thumbwheel cannot turn the control up or down. This can only be remedied by finding another thumbwheel from a junker set. The thumbwheels are made of Bakelite, and the teeth on these can be broken easily if you try to force the control.
Now, as to your other question. Is it worth fixing? That depends. If you plan to fix it up to resell, then no. If you want to keep it and enjoy it, then yes. One man's opinion...
Finally, please do not plug it in and turn it on again until you have, at a bare minimum, replaced the set's electrolytic capacitors and tested the tubes. More info on that subject here.
[split] New member...
Far as I know, that plastic insulator should be mica. I don't know if plastic is an equivalent insulator.RodB — 10:51 PM
Ok, I think I'm about done.  I've got one anomaly left but other than that, it is working great and picking up lots of s...HowardWoodard — 09:34 PM
Abandoned Zenith 9-S-367 located/Galesburg IL
As I looked through Zillow I noticed an abandoned house for sale in Galesburg Illinois for $14,900. There appears to be...bridkarl — 05:42 PM
Yesterday checked Mouser for the price on some caps and was curious about the mica equivalent. The 27pf 1kv ceramic is 2...RodB — 09:58 AM
In some cases the old paper caps can be replaced with ceramic caps, with values such as .001 uf, .005 uf, .01 uf, and ma...Arran — 06:50 PM
Vlad; I would tend to agree, I only suggested the loop antenna connections since he was already looking at the end of...Arran — 06:18 PM
Rod thank you for helping to understand the paper caps and offering the bumblebee caps. I have already ordered film caps...osanders0311 — 03:55 PM
Bob, this is the wrong sequence to look for problems and setup circuits. Always start checking the signal path from the...Vlad95 — 12:19 PM
Philco J1720 stereo and record player with reverb
The above link takes you to the Delaware Valley Historic Radio club. They are not too far from you and may have sugg...klondike98 — 11:49 AM
Tucker Movie Prop car
Richard: Did you ever check with your friend? About once a year I try to verify if Mr Rhoades really worked on the r...WrenchMonkey — 09:22 AM
