Looking for a needle for a Dynamic reproducer !
My friend ask me to fix his 46-1209 Philco, the problem that I quickly ran into was the needle in the Dynamic Reproducer was broken, point missing ! The pick-up DOES make noise thru the radio , but the tone arm just floats across the record ! I have included a link to my "Photobucket" album, showing the correct needle #001 , the tone arm does NOT have any guard ,as shown in #02 , without the guard the needle would bend quickly(#02) ! Does anybody have ideas where I could find one or two(maybe a spare) of these phonograph needles, Philco part no. 35-2661 ?
Thanks, Lee Petrie , Joliet, IL. 815-744-1051
[Image: http://i404.photobucket.com/albums/pp122...661001.jpg]
[Image: http://i404.photobucket.com/albums/pp122...266102.jpg]
(edited by site admin to show pictures)
Hi Lee
You might try West-Tech Services...I think Gib either has the correct replacement or a suitable substitute?
http://www.west-techservices.com/
Hi Ron, Thanks for your suggestion of "Gib" at West-Tech, I just sent him an email/with pictures! Lee
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 986 online users. [Complete List]
» 1 Member(s) | 985 Guest(s)
