41-290 FM Reception and Antenna
I have restored a 41-290.  Everything is working except I cannot pick up any FM stations.  I do get some static, but that is it.
I have attached a schematic.  I believe that the FM antenna connection is below the "2" in the upper right.  Can someone please confirm?  Also,  what can I check/adjust to try and get FM to tune in?
On a side note,  I installed an auxiliary input and played the FDR Infamy speech. Chilling.
TIA
41-290 does not have FM.
It has BC and two SW.
That would explain it!
My dial face must have been replaced with a non-original at some point.  Attached is a pic of mine.
Yeah that plate doesnt look like mine.
First Radio restoration
There are currently 1474 online users. [Complete List]
» 1 Member(s) | 1473 Guest(s)
