Electrolytic negative leads
It took five weeks, but I did it!  All 20 paper caps replaced on the 46-1209.  I'm starting to get the hang of this.
Now, the electrolytics.  I decided to restuff the cans, starting with 10 (25 + 10 mfd).
I understand where the two positive leads go.  For the negatives, do I solder them together and that's it, or do they have to be in contact with the can?
Solder them together and connect them to one of the negative terminals of the can which is the connection to the can.
Ah, okay!  To one of these tabs, right?
And I drill through the sawed off "lid" to pass all leads through?
Looks like you have the positive of the 25uf connected to the neg. of the 10uf.
Yes you can drill holes along side the tabs you want to connect to.
Indeed I do. Good catch!
The 25uf is an axial and its negative lead isn't long enough to reach the can's tabs. Can I solder the negative lead to the inside wall of the can? If not, what type/gauge of wire should I use to extend the lead?
Apologies for the simplicity of the questions (there *will* be more).
Since the can is probably aluminum you will have a difficult time soldering the wire to the can. Extend the negative lead with a 22 gauge wire and run it to the negative terminal.
Thank you, RodB! Done. Now, on to my next first: the infamous Bakelite block!
Philco 91 Restore Code ??
I think that Danaher, the company that owns Beckman-Coulter (the company that I worked for 41 years) owns Fluke. They a...MrFixr55 — 08:35 PM
Rod I wish... :lol: I am not sure I'd buy the Fluke, had it not fell in my lap for free. $500 to $800...it's a lot...morzh — 08:09 PM
Mike, ...you get a commission?RodB — 07:52 PM
New member
Hi. I specialize in refurbishing Predictas, but I'm in Chicago. If you can get it to me, I'd be happy to go over it. ...Bob Andersen — 06:43 PM
I have 3 G speaker, all with open Field coils. Today I pull one of the shelf and decided to try to remove the FC (spo...morzh — 06:07 PM
Thanks Mike. I will check them out.dconant — 05:52 PM
There is no such thing as bad Fluke. This said, they are expensive. A Fluke is easily 10x the price of comparable CCC...morzh — 05:45 PM
Hello Mike, Yes, I have 3 Fluke meters one being my first Fluke 77 and other being Fluke 87. My third is Fluke clamp -...radiorich — 05:04 PM
I knew that Fluke was the Cadillac so with that in mind what Fluke would you recommend I get?dconant — 03:53 PM
Yep. 10W is probably enough. Also, if the meter measures Farads, then it should also have that "Delta" button...morzh — 02:38 PM
There are currently 2181 online users. [Complete List]
» 3 Member(s) | 2178 Guest(s)
