Refinishing a Philco 38-7 floor model cabinet
I am in the process of restoring a Model 38-7 cabinet which is quite sun-bleached in most places. Because of the sun bleaching and portions of the cabinet where the finish is cracked and worn, I feel sure that I will have to refinish the cabinet.
Does anyone know how the cabinet was originally finished? Was it a toned lacquer? If so, what color was used, and was there only one color originally on the cabinet or several? The radio does apparently have a wood inlay across the face which does appear to be a lighter color than the rest of the cabinet. However, the difference in color may be because of the difference in the underlying type of wood.
Thanks in advance,
John King
Hi John
The original finish was tinted lacquer, with a coat of clear lacquer added after the tinted lacquer.
All of the 38-7XX cabinets I have seen were all one color: Medium Walnut. Either that or Perfect Brown (both Mohawk colors) is what you will want to use.
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
