tuning condenser max value for part# 31-2658
Does anyone know the max tuning cap value for part#31-2658. I'm trying to use a parts 46-200 to build a transmitter and would like to use the tuning condenser, dial scale and case.
If you use it with the coil (the loop antenna in this case) from the same set, the tuning range will hold for the most part. Philco did not publish min-max values for their tuning gangs, only the max uuf values from the very early 30s sets.
You can always use a cap meter to check it anyway.
I looked thru the documents and did not see one. Might have missed it though.Jim Dutridge — 07:16 PM
Please tell me this was it, I replaced resistor 27 and it's playing on the broadcast band. I am afraid to change the ban...osanders0311 — 06:12 PM
So far still no broadcast, I am posting pictures of #14 Oscillator and also a resistor #27 which connects to an XXL tube...osanders0311 — 04:02 PM
I believe there is that document, and I think we might have it in the Library.morzh — 03:29 PM
5U4 vs 5Z4 tubes
There are currently 950 online users. [Complete List]
» 1 Member(s) | 949 Guest(s)
