50-1724 cabinet restoration
Restoring a Philco 50-1724.  The top has a gold scrollwork pattern that runs all around the edges.  It's faded, and I can't tell what the original color of the top was.  I've seen pictures that show it as a forest green, but I've also seen where it's described as a thin leather overlay.   Anyone have any ideas?   Here's a picture of one in good shape, but the three front knobs tell me this is not a 1724 - but the top looks to be the same.
Well, I guess I'm the only one who's encountered this issue with a cabinet. I'll keep searching and post anything I find.
yep, I don't recall seeing a post on that issue.
That kind of a "finish" was not uncommon from the 1920s on. Most, but not all, were faux leather. Some had graphics added some did not. In general, if you have such a radio and the "leather" is in OK shape I would not mess with it.
Somebody that does that graphics style like Buford Chister (speaker cones) could probably do a good job on the correct material (and color).
Wurlitzer C-3 from 1924 pictured:
Russ
P.S. Maybe a little Armor-All. It might work, or make a mess, try it in a small area, hidden if possible.
Thanks, Phlogiston -
That's very interesting how this finish was used way before - thanks for the picture.  I would have never thought of Armor All.   I will try it in a small corner and see.   Another thought that occurs to me is the possibility of getting a stencil cut and reapplying the gold filagree if the original doesn't survive a gentle cleaning.
Help with Supreme 599
5U4 vs 5Z4 tubes
5U4 vs 5Z4 tubes
5U4 vs 5Z4 tubes
Ok.... In the fourth year of the war, I still decided to return to an active hobby. For more than three years, I did not...RadioSvit — 10:43 AM
