6k6(G) Tube and the Hickok 733 (or all)
I noticed that the test settings for the 6K6 on my most used tester are probably wrong. It show  a GM of ~1400 with a different bias. I actually looked because some of the Crosley 6K6s I have been buying tested REALLY GOOD by the seller.
It would appear that testing this tube with the 41 (tube) settings results in a more accurate test with a GM around 1600.
Russ
