Philco TH-1
Could you tell me what type of wood I'm dealing with? Any accent or areas where darker lacqure were used? Appropriate style grill cloth? And where do you find those small staples used to hold the plastic dial cover in place? Thanks for the advice.
David Woodward
Hi
For the cabinet colors, I suggest Medium Walnut for the top, front panel and sides; Medium Dark Walnut for the trim between the front/top and sides, and along the bottom edge trim.
Appropriate grille cloth is Pattern #14 from Radio Grille Cloth Headquarters.
Sorry, can't help you on the staples...maybe someone else will offer a suggestion.
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 2354 online users. [Complete List]
» 2 Member(s) | 2352 Guest(s)
