OSCILLATOR
My set philco 111 . Will quit receving anything . So i decided to check oscillator plate voltage good 65 volts . decided to check other voltages
touched wire from oscillator plate to osillator coil started working . It will play for hours turn off have to do this almost every time.
I left cover off so i can touch this connection . What do you think strange i know . But this set has been a pain from the get go. Icon_mad
Any ideas Thanks Kent.
Possibilities and things to try:
Bad tube cap maybe. Try a known good tube.
Have you re-capped the set?
Bad tube socket.
Bad/cold solder joint.
Bad cap or resistor no replaced.
Intermittant continuity in the osc coil. (VERY common for Philco coils to be open due to corrosion in trhe windings or right at the solder lugs.)
The coil form could also have moisture in it.
Also check your oscillator tube, a type 27.
Chuck has already mentioned the most likely possibility: intermittent continuity in the oscillator coil, which calls for a rewind.
Hello murf! I merged the threads. Please do not start new threads regarding the same radio. Take care, - GaryGarySP — 10:21 PM
Regarding picture 5 on page 1 of this thread this capacitor is #40 on scematics diagram - 4mF+4mF. Black wire is "-...Vlad95 — 09:01 PM
That's a dual 4 MFD, red and green are both 4mfd and black is common negative. You should be able to see them in the pow...RodB — 08:58 PM
Can anyone help me figure out a capacitor that has 3 wires coming out of it red and green on one side and a black wire o...osanders0311 — 08:14 PM
Two small radios from France. Restoration and review.
Greetings; I think that it's possible that the assortment of components was the result of post war parts shortages, a...Arran — 12:18 PM
Unfortunately I can't inject any audio into the volume control. It is in the primary circuit of the antenna coil, not in...Stormlord5500 — 09:32 AM
Sounds good Gary I'll do that. I have plenty of stuff like that I can scrounge up. I am still kind of new to all this so...Stormlord5500 — 08:47 AM
Philco Battery-WWII vintage
Seems to me that this a general purpose or radio filament 6V battery of very high amp-hour capacity and very high "...MrFixr55 — 08:08 AM
You should be able to inject an audio signal such as from a CD or mP3into the radio at the volume control. The set will...MrFixr55 — 08:14 PM
Hello guy's, Have a Trutone A2-G teledial floor model radio that I am having issues with. Suspecting maybe speaker or ...murf — 03:25 PM
There are currently 258 online users. [Complete List]
» 3 Member(s) | 255 Guest(s)
