Philco 46-250-I
See also the cabinet thread.
After getting the chassis out, here's my first look at the state of the thing.
[Image: https://www.dropbox.com/s/6d70qjvng0fbbt....jpg?raw=1]
[Image: https://www.dropbox.com/s/alvmrioh7lt27w....jpg?raw=1]
The dial scale is held in place with 4 screws and two metal strips.  The glass itself rests on two strips of rubber which of course have deteriorated but should be easy to replace.
[Image: https://www.dropbox.com/s/w5wxnwiqqngqec....jpg?raw=1]
The original electrolytic firecracker style cap has been replaced with a Sprague and lots of extra wire!
[Image: https://www.dropbox.com/s/edg9gq3hybgli1....jpg?raw=1]
Here's an image (from an internet search) of an original.
[Image: https://www.dropbox.com/s/rtlbw8nac4vamp....jpg?raw=1]
Good news is the candohm style resistor R100 is good.  I will take off the tuning cap and give it a good wash since I doubt I could really get it clean while still in the radio.  One of the two dial strings is already off anyway.  The on-off switch was showing some resistance when it should have been closed so I took it off the set and gave it a little spray of cleaner.  That seemed to clear it up.  I used just a little of the DeoxIT Fader F5 since the regular DeoxIT can damage the volume pot section. More later...
Since you stated earlier, you have a console 38-7XX.  They also had a 38-7T (table), and 38-7CS (chairside).  A very nic...GarySP — 01:18 PM
That I wouldn't know, but sometimes the radio document itself shows one, same as the capacitor cans' etc pinouts.morzh — 12:46 PM
Thank you morzh, that is exactly what I was looking for. Now , is there some where that shows pinouts for Philco power ...Jim Dutridge — 11:37 AM
There are currently 1244 online users. [Complete List]
» 2 Member(s) | 1242 Guest(s)
