Philco 38-4 Electrolytic Cap
I have a Philco model 38-4 and it has a 30-2200s can with a 18uf 475v electrolytic capacitor. On the bottom in the center is a tab to connect and one on the side. I need to replace it but I am not sure if the center is positive or negative.
Anyone know?
Picture attached
Center is+ the tab on the side is -.
That is what I was thinking, thank you for confirming!
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
Refinishing Ideas
Hi Doppelganger, After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM
Philco model #20
Hi Rick, One other thing regarding volume on this set.  Make sure that the tube shield is in place.  this is that la...MrFixr55 — 08:22 AM
Philco model #20
Hi Rick, The volume control on the Model 20 has 2 sections and does 2 seperate things: One part of the control, ...MrFixr55 — 10:30 PM
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
