Philco 39-116 attachment question
Hello Philco Pfolks
Not sure if this should go in Cabinet or Electronic restoration but seems more cabinet orientated. Please feel free to move it.
I am in the final stretch of a L O N G restoration of a 39-116 and mystery control.  I originally received the radio in pieces.  I am now attaching the speaker to the speaker board ( 4 studs with 4 nuts and fiber washers) and have a question for the phorum.
Was there a thick cardboard spacer/gasket that fit between the speaker lip and speaker board, or was the speaker just mounted directly with the metal rim of the speaker mounted on the wooden board?
 It appears that there might have been a ½’ wide washer around rim where the speaker cone mounts to the metal frame, but it may have just been an indentation from a fixture used when the cone was originally attached to the frame.  I’m not sure so I thought I’d ask if anyone was certain how it was mounted.
Thank you,
Fran
The speaker would have been mounted directly to the speaker board; no gasket used.
Ron, Thank you so much.
Very handsome radio, and a nice resto job!!!
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set war...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
schematics
Richard, thanks so much, greatly appreciatedmseno — 08:39 PM
I'm starting to restore a Philco 16X, I need spare parts. Please, help me find ...
Peter; I believe that the "A" suffix means that it has as 25 cycle power transformer, not all Canadian sets...Arran — 07:05 PM
I am back tracking on my resistors as the one that burned based on the old one's resistance was correct but another resi...osanders0311 — 05:34 PM
"So you can see how Important it is to identify parts with the schematic, especially when you have multiple parts o...osanders0311 — 05:23 PM
