VTVM meter moves when my hand is next to it & not on
Threads: 4
City: Lindsborg
State, Province, Country: KS
This is strange to me. Maybe in over 50 years of working around swinging, analog meters I just never saw this, I have missed other things also along the way.
This morning I unboxed a V7 Heathkit and began investing it's innards. Looks clean has a dead carbon zink battery, not leaking yet? pulled it quickly. Noticed the 3 capacitors are original, so I plan to replace them check tubes and replaced the half weak 12au7.
Noticing the meter not setting on Zero, I decided to set it on zero. When I place my hand on the case to support it while I twist the adjustment screw the needle moves. I set the needle to zero but when I move my hand away the needle moves away from zero. Tricky little guy! So I don't put my hands close to the meter, instead l use a long screwdriver and zero the meter. With the meter set at zero I place my hand next to the meter and it jumps up swinging rather high stays up until I bring my hand back. It doesn't return to zero when it comes to rest. This is with no power on.[attachment=32248]
Bruce B
Any metal/magnetic things IN or ON your hand?
Or it is on high sensitivity limit, and measures charge on you? Or on AC and measure somehow the signal through your capacitance?
Threads: 4
City: Lindsborg
No, I,m explaining it is turned off, not plugged in. Its not measuring anything! I don't have metal in my hand and I have moved my hand over several other meters I own without anything happening.
I have been trying to post a video but it keeps quiting at 21% so I will put this link in here and you can see what's going on.
https://photos.app.goo.gl/6tYYT8y3x3zSG1if7
Bruce B
Threads: 55
City: Roseville, MN
That's static electricity. Take a used fabric softener dryer sheet and wipe the dial cover then discharge your body to the nearest earth ground (or is it vice-versa?). You can now set the pointer to zero. Happens a lot in the winter-spring. Keep the dryer sheet close by.
Threads: 4
City: Lindsborg
Thanks Bob,
I was kinda figuring on that, but I have never seen anything like this guy does. It's inability to come back to rest at the same point is strange. I will see to the un-static sate of being for me and the meter, then I will try again. I'm going to recap it tomorrow and calibrate. I will then put it on the shelf as I really didn't need it, but $6, you know....
Threads: 55
City: Roseville, MN
Can't turn that deal down.
Threads: 4
City: Lindsborg
It's okay because my wife hoards yarn, so one more piece of radio rest equipment is ok too
Threads: 53
City: Menlo Park
State, Province, Country: CA
Static electricity - but the other chaps beat me to it again. I've seen this before with analogue meters.
I've also seen related effects that will make liquid crystal displays (calculators and clocks etc.) act strangely, until the surface charge dissipates.
I remember using a VTVM (I think a Heathkit model) for one of the experiments in our first-year physics practicals series. Our labs were a bit archaic...
The second year lab had an AR88D in the corner - I wonder what happened to it?
Threads: 55
City: Roseville, MN
Ed - it's in the Cayman's enjoying the good life.
Threads: 53
City: Menlo Park
Haha! I hope so. It seemed rather lost and forgotten languishing in the frozen Northeast of England.
Threads: 3
City: Derby
As others have said, it's static charges. The manuals for the RCA VoltOhmysts had an elegant solution - put a single drop of liquid dish soap on a soft rag, and spread it on the face of the meter. It works, and lasts many years.
| Ok guys. Thanks for the input. As for AI this is why I ask the experts.
Dandconant — 07:39 AM |
| Technically, that's C-. B- is chassis ground. The resistor between chassis ground and the HV center tap makes the HV c...MrFixr55 — 11:24 PM |
| hello Roy,
I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM |
| This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM |
| Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM |
| Roy;
Personally I would have left the asbestos alone if it were my set, but you can find a modern substitute that som...Arran — 04:51 PM |
| Looks like that might be the B- buss, so that would be correct.RodB — 01:32 PM |
| I noticed on the code 121 schematic the center tap for the 6 volt winding and hv winding are tied together. Is this corr...dconant — 12:16 PM |
| The Philco Parts Catalog for 1942 shows it as usable for 175 kHz, 260 kHz, and 465 kHz. The instructions will show how t...DaleHCook — 11:19 AM |
| Hello Rob,
I agree with you—I have one here at my house that I need to check out. It’s way over-engineered just to make...radiorich — 11:05 AM |
There are currently 1912 online users. [Complete List] » 3 Member(s) | 1909 Guest(s)
