77 low volume
While waiting for parts for my 87 I finished up my 77. All excited I fired it up. No volume until I touched the volume control shaft, top of the 1st rf tube (24), or the coil #5. Checked coil resistance 6.2 ohms from cap of 24 to gnd. matches other coils, volume control pod, ground connections, and voltages, all look ok. Ran a jumper from 24 cap connection on coil to ant. got a little better, but not as good as if you touch it. Some stations you can hear faintly, but others not until you touch. Tried swapping tubes, no difference. Probably something simple staring me in the face. Frustration got the best of me at this point. Any and all ideas welcomed. Thanks ahead of time, Richard
Check for continuity in both windings of transformer #2;
Both sections of coil #5;
All three sections of coil #9 and #10.
Check for B+ on plates of both RF tubes. If missing on either plate, it's a coil winding associated with that tube.
(I assume you already replaces all the wax-paper caps and any out of tolerance resistors.)
Hi Chuck, Thanks for the reply. #2 from volume center tap to gnd. 20.9 ohms, gnd. to tab for coil #5- 6.2ohms. Coil #5 center tap 6.2 and 6.1 ohms. Coil #9- 45.7, 6.3, 1.5 ohms. Coil #10- 48.5, 6.2, 1.5 ohms. B+ voltage on plates 154. All capacitors and out of tolerance resistors were replaced. Also before replacing anything there was a wire bridge on the bc resistor connecting H & J. I removed it since I could not find it on any schematics or updates. The resistor tests good between H & J 2,054ohms. specs. 2,000 ohms. Also a 24k dog bone resistor was in parallel with resistor #12 a 100k. I also remove it. Both seem to have been added a while back. Thanks, Richard
@ Joseph, get off the porch and run with the dogs. You fixed one, grab another. @ Morzh, I think that we are the same ...MrFixr55 — 08:59 PM
Philco Model 249 made in England
Wow! Now that is something! I’ve never seen a Philco like that, but it’s pretty mid-century.jrblasde — 06:40 PM
I've run the radio for a couple of hours today, and all is well. It's a remarkable sounding radio! I'll go ahead and upl...jrblasde — 06:05 PM
Gary - Thanks for responding!  I hadn't actually taken possession of it at the time of my post but since you said it was...fklown — 03:32 PM
Philco model 40-100
Marion; Replacing volume controls was something some service shops did in years gone by to make a little extra profit...Arran — 03:24 PM
Welcome to the Phorum, fklown!  That's one heck of a Philco 'yardstick' you've got there!  Could you possibly post a clo...GarySP — 03:19 PM
Philco model 40-100
Arran, Thank you so much for your assistance and the link to the fleabay listing! They say a picture is worth a thousan...mhamby — 01:43 PM
I wonder if anyone has any information or experience with this model.  My internet searches are coming up with nothing. ...fklown — 11:40 AM
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
There are currently 421 online users. [Complete List]
» 2 Member(s) | 419 Guest(s)
