Threads: 3
City: Tampa, FL
I was given this old Philco cathedral radio and am trying to find out the model and year it was made if possible. There are no markings on the chassis or wooden case that I can see. I hope the pics will tell the story.
I'm sure you guys know...right?
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
Best regards,
Kico
"I whisper, but my horse still doesn't listen."
Hello, and welcome!
You have a Model 84B, the late version from January 1936:
http://www.philcoradio.com/gallery/1936b.htm#c
That is an oversized power transformer. Might be a 25 cycle model? If so, it will work on today's 60 cycle line current.
Threads: 3
City: Tampa, FL
Thanks Ron,
I tested all the tubes and they all check good. I then fired it up on my dim bulb tester...as expected a very loud 60 cycle hum but no smoke  ...faulty power supply cap I suspect.
Any good links here on the forum for rebuilding one of these?
Thanks again...
Best regards,
Kico
Threads: 268
You may want to search this site for similar models like model 80,84,600, 57,37-84.
Threads: 3
City: Tampa, FL
7estatdef Wrote:You may want to search this site for similar models like model 80,84,600, 57,37-84.
Thanks Terry,
Whew...there's a lot here. I was wondering if anybody has compiled a component list (caps/resistors, etc.) needed for rebuilding an 84B they could post or send me? My eyes are not what they used to be, and reading the actual and schematic values is difficult. I'd like make sure I have the correct parts before I place an order.
Also, could someone on the forum link me to the correct schematic for this radio...thanks.
Best regards,
Kico
May I suggest you contact Chuck Schwark to obtain the service information package for this radio, which will include an 11 x 17 enlarged schematic, parts list, alignment info, changes, etc., etc.
http://www.philcorepairbench.com/schematics.htm
Well worth the nominal fee.
Threads: 3
City: Tampa, FL
Thanks Ron...I'll do it!
Best regards,
Kico
Threads: 12
City: Nashville, TN
Hi Ron,
I am working on one of these right now, the exact same cabinet. But the inside label says it's just a model 84. Does the 84B just refer to the style of cabinet, and is not marked so on the blue tag?
I do have another 84 but with the more circular cabinet.
Kico, I posted some photos an info for you on your other thread.
Thanks. Gary.
Hi Gary
Yes, the "B" referred to the style of cabinet; in this case, "B" = Baby Grand - which is how Philco referred to its cathedrals and tombstones back then. The terms "cathedral" and "tombstone" did not come into general use until decades later, as people like us began to collect these radios.
The sticker on the back of the chassis will read "CHASSIS TYPE 84" without mentioning the cabinet style.
Threads: 12
City: Nashville, TN
Thanks Ron, that clears up the mystery.
Working on the cabinet today, shouldn't be too bad. No veneer or photofinish to worry about.
Take care,
Gary
Yes, Michael. But strangely enough, I managed to keep the original veneer. I must admit that I don't really like it, so ...RadioSvit — 02:21 PM |
Good radio.
I bet there was a lot of veneer fixing.morzh — 02:16 PM |
>> it is because I am retired and a little demented.
You have just the right amount of it. No perfectly sane p...morzh — 02:14 PM |
Old Zenith 5S-29 tube radio. First turn-on after repair and reception quality testing. Demonstration of the operation of...RadioSvit — 01:27 PM |
Welcome to the Phorum, osanders0311! Regardless how far you intend to restore this set, first priority should be replac...GarySP — 11:51 AM |
Joseph, it is because I am retired and a little demented. My problem is that I wanted to own a collection that spans th...MrFixr55 — 11:29 AM |
Wow, here I am with only two restored radios. I’ve got to boost those numbers! If you can’t run with the big dogs, you m...jrblasde — 10:04 AM |
Hello MrFixr55,
That will for sure keep you out of trouble!
Last Sunday was spent mostly doing yard work anyway the we...radiorich — 09:50 AM |
Throw in all the Audio equipment that has to be kept in a bedroom (my office)L. 8 portable self contained PA speakers, ...MrFixr55 — 07:40 AM |
Looking at the pic supplied by Rod B, you can duplicate the missing loop antenna. 10 gauge copper wire can be used to m...MrFixr55 — 01:20 AM |
There are currently 726 online users. [Complete List] » 1 Member(s) | 725 Guest(s)
