Grille Cloth Recommendations, Model 70, 37-620
What grille cloth do you guys recommend for the model 70? I normally use http://www.grillecloth.com/. I read some postings where Pattern #1 was used. Has anyone tried pattern 24 (Philco, weathered look)? I do not have an original to compare with in this case.
Also, I assume the correct cloth for a model 37-620 is pattern 14 (Ribbed), with the ribs vertical. Correct?
Thanks!
I use pattern #1 for most Philco cathedrals made through 1933, since this is the correct, original pattern for these (exceptions being models 80 & 81). I don't care for the "weathered look," it does not look original at all. Pattern #1 does look original.
Quote:Also, I assume the correct cloth for a model 37-620 is pattern 14 (Ribbed), with the ribs vertical. Correct?
Yes.
Philco 89 Code 123 Osc Coil
I pulled the tube out and it's shorted from pin 1 to pin 2. I suppose that's the problem...sq65 — 08:12 AM
