Model 37-630 output transformer
Can anyone recomend a replacement output transformer for a model 37-630 console? I have been looking at the ones in the AES catalogue but I have no idea which one would work. The Philco part # is 2580-P
Jon.
Well my old RCA tube manual sez the plate impedance is 7000 ohms. So that you are looking for is an output transformer that will match 7000 ohms to 4 ohms (voice coil) Needs to be able to handle about 4 watts or 40ma primary current.
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
There are currently 365 online users. [Complete List]
» 2 Member(s) | 363 Guest(s)
