Threads: 1
Hello all,
I am new to the forum and I'm not even sure if I should be here...
I am in New Zealand where the Philco model numbers are not the same as the USA ones.
Nevertheless, I'm hoping that someone may be able to point me in the direction of a schematic for a Philco Model 732 (S/No: 14053)
Valve Lineup: 7B7, 7A8, 7B7, 7B6, 5Y3, 6V6
Broadcast plus 4 SW bands covering 49M to 16M
Perhaps there is a USA model which has the same lineup and I might glean some clues from that.
Any suggestions welcome.
Many thanks!
Threads: 270
Hi and Welcome!
Sure you can be here! It maybe a big help to post a picture of your set. Or you could take a look in the Gallery to find it.
Threads: 1
Hello Terry,
Thank you for your encouraging words!
I will take some more shots tomorrow of the "innards", but here it is as I received it.
Also, I may be a wee bit slow, but how do I access the Gallery?
Cheers1
Noel
Note from site admin: Sorry, but the photo which was attached to this post is no longer available.
Threads: 2
Based on some information found it was made in 1947 by Philco New Zealand. Sets for Philco New Zealand appeared to be manufactured by Dominion Radio & Electrical Company (DRECO). Other than this information I'm not able to find much unfortunately... I'd say based on cabinet design alone it looks most like a model 46-132 but it's not the same since the US model is AM and it appears only one SW band.
http://www.radiomuseum.org/r/philco_732.html
http://www.radio-restoration.com/Philco.html
http://www.trademe.co.nz/Music-instrumen...299571.htm (good picture for restoration reference)
Brian Mattson
Coon Rapids, MN
Threads: 270
