Philco 47-1230 restoration
#31
There is more info on the safety caps here
http://www.justradios.com/X1Y2capacitors.html
-Keith
#32
Early production 47-1227 sets used a bakelite block which contained two capacitors as the AC line bypass. This was changed in Run 3 to two separate mica caps.
The same change was made to model 47-1230.
A plug for Chuck: this is one example of the kind of information you can get in his service packets.
http://www.philcorepairbench.com/schematics.htm
As you have two mica caps as the AC line filter, as stated previously, they should be replaced with two X1/Y2 safety caps.
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
There are currently 638 online users. [Complete List]
» 1 Member(s) | 637 Guest(s)
