My latest Philco restorations
[Image: http://home.comcast.net/~morrised2006/ra...pt25~1.jpg]
Philco Transitone Model PT-25
1940 Philco PT-25 five tube AM receiver. My brother gave me this radio for Christmas in 2009. The cabinet was in very nice shape, but there was a lot of rust on the chassis, the power cord was rotted away, and the dial pointer didn't turn. I pulled the chassis and recapped it, and replaced one out-of-tolerance resistor. All the tubes tested good. They are all Philco tubes. The pilot/dial lamp tested OK as well. I used Naval Jelly and a wire wheel in a Dremel tool to remove the rust from the chassis. The dial cord was intact, but stretched, so it was slipping on the tuning knob axle. I restrung it with new dial cord. The speaker cone had also come unglued from its basket, so I had to fix that. When I attached an antenna and powered up the radio, it played beautifully, with the nice characteristic sound of these little Philco's. I cleaned the cabinet with Brasso and Novus, then buffed it with Carnauba wax. I replaced the yellowed dial cover with a new one from Art Deco Radio, and reinstalled the chassis. Its only flaw is that most of the back of the radio is missing.
[Image: http://home.comcast.net/~morrised2006/ra...6250~3.jpg]
Philco 46-250
1946 Philco 46-250 bakelite AA5 AM receiver. The cabinet was also a gift from my brother for Christmas, 2009. I began searching for a chassis to fit in it and after a time found a model 46-250 on Ebay with a badly damaged cabinet. The electrolytic caps had been previously replaced and the radio played very well, despite a rusty chassis and a number of rips and gaps in the speaker. I used Naval Jelly to remove the rust from the chassis, and then painted it. I replaced the discolored dial background with a new white background. I repaired the speaker and replaced the other wax capacitors and installed a new AC cord. I put the chassis in my cabinet, and now have a very nice looking radio that plays like new.
A couple of real nice set!! Keep up the great work!
I'm not a bakelite guy, but you got both of those radios looking d**n good!! Well done!
Great restorations, thanks for sharing these with us.
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
