Model 66b Warm-up drift
Replaced all electrolytic & paper caps along with 6 resistors. Did not replace the bakelite caps. I've noticed that it takes about 15 minutes for the radio to warm up and stop frequency drift. Is this normal for a 1935 radio or could it be attributed to another item, such as bakelite caps? Bob. Icon_confused
All old sets drift a little bit. I think you probably still have one or more carbon resistors that is high in value, and it gets worse with a little heat. At a nickel or so apiece, why haven't you replaced them all? Wirewounds are either good or bad or shorted to the chassis. It's a crapshoot with mica capacitors, usually you get crackling or loss of signal, but drifting could also occur. Of course there are more bizzare things that could be going on too.
Let's see who else has some tips.
Hi Bob,
Well, it wouldn't be unusual to note some drift in the first 15 minutes but the question is how much is too much. In relative terms you should be able to turn it on to an AM station and maybe have to touch it up slightly once after warmup. Shortwave would be different.
I can't think think of a scenario where any of the Bakelite caps would cause this unless they were really leaky and pulling down the voltage - and that's not out of the realm of possibility. I'd rebuild them on general principle because there's so many other potential problems that could develop.
If you have another 6A7 handy you might try it. I've caught excessive drift in many radios due to some problem with the LO/Converter tube.
Just my 2 cents.
-Bill
Thanks for the replies. Besides not replacing any of the bakelite caps, I also did not replace any of the dog-bone resistors. Looks like I have some more work to do. Bob
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
There are currently 646 online users. [Complete List]
» 1 Member(s) | 645 Guest(s)
