Need info on these caps
I am trying to recap a philco 38-4 and need some info on the tall elctrolitics on top of the chasis.The philco numbers on the cans are as follows.30-2200a,30-2201a and 30-2212a.What parts do i need to order.???Any info you could provide would be greatly appreciated by this neewbie.Thank you in advance.
Hi Kelly and Welcome!
What you are looking for to replace the two filter caps are: for #64 it's a dual job original value is 10 uf and a 8uf. Would replace with two 10uf @ 450v. #66 is an 18uf original replace with a 22uf 450V. There is also #26 a 16 uf replace with a 22uf @450v
A lot of these caps aren't standard sizes anymore so the values I've given you are standard size now. Service info can be found here:http://www.nostalgiaair.org/Resources/250/M0013250.htm From the service info it looks like it ought to be a good playing set after servicing.
Good luck w/it
Admin Note: Made URL into a link.
Now I think I've got it!
There are currently 2402 online users. [Complete List]
» 1 Member(s) | 2401 Guest(s)
