Phorum How-To #2: How Do I Find the User Control Panel?
Scroll to the top of any page in the Phorum and click the User Control Panel button as shown below.
[Image: https://philcoradio.com/images/phorum/Ph...02_001.jpg]
Or on your phone, tap the green icon at upper left as shown below.
[Image: https://philcoradio.com/images/phorum/Ph...2_001m.jpg]
On your computer or tablet, you will be taken to a page that looks like the one below:
[Image: https://philcoradio.com/images/phorum/Ph...02_002.jpg]
And on your phone, the page will look like this:
[Image: https://philcoradio.com/images/phorum/Ph...2_002m.jpg]
Here, you can do many things, such as change your username, change your password, and other stuff. All of these options are covered in separate How-To threads.
WARNING
Please read all of the How-To guides before changing anything! Simply making changes without knowing what you are doing may leave you with an unusable Phorum!
Ok guys. Thanks for the input. As for AI this is why I ask the experts. Dandconant — 07:39 AM
Technically, that's C-. B- is chassis ground. The resistor between chassis ground and the HV center tap makes the HV c...MrFixr55 — 11:24 PM
hello Roy, I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM
This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM
Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM
