610 volume fluctuation
Hi - I'm enjoying my recapped Philco 610, which works pretty well even though the antenna arrangement is less than ideal - but I noticed that the volume level is normally pretty low (you need to turn the volume knob a long way although it is progressive in its increase) . The other day, the volume suddenly increased massively, requiring me to dash across the room, scattering barking dogs and crying children in my wake, to turn it down again. It later dropped right back again. The effect is sudden not gradual.
Poking around, I noticed I can sometimes create the same effect by tapping the top of the 75 tube (second detector). This tube tests rather weak - I would usually have said it would be alright. Does anyone have any experience of this phenomenon, or ideas for what I should check for ?
Its not a big deal really - but has me puzzled.
Is the grid cap on the tube loose? I am talking about the silver cap that should be premanently affixed to the top of the tube, not the wire connector end. If yes, that could be the issue.
Try replacing the 75 with a strong tube and go from there. The 75 is the first audio/2d detector tube, and the volume control feeds the grid of the 75 through a .01mFd cap.
(03-16-2012, 12:17 AM)TA Forbes Wrote:  Is the grid cap on the tube loose? I am talking about the silver cap that should be premanently affixed to the top of the tube, not the wire connector end. If yes, that could be the issue.
It could also be a flakey solder joint on the lead near the clip, or the wire breaking internally near the clip, those are pretty common problems around a grid cap along with the cap itself.
Thanks for the ideas - I'll check all these points - I just want it to work as good as it can !
I have recapped this large Marconi model 86.  It plays quit good.         I have stripped the cabinet and using Mohawk...Dan Walker — 12:18 AM
Table radio 51C or 52C?
I think what you may have is another Phactory Phranken Philco, if the holes in the front panel lined up it was not unusu...Arran — 10:41 PM
Ho OSanders, Sorry, I got really busy in May and haven't seen your thread in a while.  I am VERY sorry about that.  ...MrFixr55 — 10:30 PM
Philco 45L Initial Check Up
Dan; I don't think that the model 45 is especially know for coil problems, not that they can't occur for one reason o...Arran — 10:19 PM
Yes, the end with the groove is positive, the stripe with the arrows points to the negative lead. The arrows have minus ...RodB — 09:36 PM
Thank you Rod and Paul I took a break, did some yard work and Rod "Therefore, it appears cap 40 is connected backw...osanders0311 — 06:35 PM
Hello, I am in the process of checking out a Philco 45L. My question is does this model suffer from the Philco coil r...dconant — 06:11 PM
Purchased a table radio at auction, not because I had to have it, but because no one else bid on it.  $5  Unable to fi...antiqueradionut — 05:14 PM
The 2 towns you mentioned "Frustrated" and "Give Up" are places we have all been. Relax, take 5, thi...Paul Philco322 — 03:23 PM
Philco 89 Code 123 Osc Coil
Thanks for posting that information!klondike98 — 03:14 PM
