Emerson DB-296 Kicking My Rear End Hard!
For the last two days I've been trying to get an Emerson DB-296 that I bought last weekend at a swap meet. It didn't play when I purchased it. I've re-capped it, checked the resistors, checked the tubes, etc. etc. etc. I have audio, but little if any signal. I've aligned the IF cans, checked continuity on all coils.
I checked tube voltages and here's what I have:
TUBE = 12SA7
PLATE ACTUAL 95 = RIDERS SAYS IT SHOULD BE = 88
SCREEN ACTUAL 106 = RIDERS SAYS IT SHOULD BE = 88
CATHODE ACTUAL 0 = RIDERS SAYS IT SHOULD BE = 0
TUBE = 12K7 (NO PLATE OR SCREEN VOLTAGE)
PLATE ACTUAL 0 = RIDERS SAYS IT SHOULD BE = 88
SCREEN ACTUAL 0 = RIDERS SAYS IT SHOULD BE = 88
TUBE = 12SQ7 (REALLY HIGH ON THE CATHODE VOLTAGE)
PLATE ACTUAL 55 = RIDERS SAYS IT SHOULD BE = 30
SCREEN ACTUAL 1.5 = RIDERS SAYS IT SHOULD BE = 0
CATHODE ACTUAL 103 = RIDERS SAYS IT SHOULD BE = 0
TUBE = 50L6
PLATE ACTUAL 86 = RIDERS SHOULD BE = 82
SCREEN ACTUAL 5.4 = RIDERS SAYS IT SHOULD BE = 88
CATHODE ACTUAL 6.0 = RIDERS SAYS IT SHOULD BE = 5.6
Any suggestions would be greatly welcomed!
I always considered it a good and consderate thing when the asking party psts a link to the sch in question intead of sending those trying to help to search for it.
We are willing to help but why make us do the legwork?
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
