My New Philco 15x
Bob, thanks for a closer look on your audio transformer, mine is the same, does yours have anything stamped or inscribed on the clam shells? Mine has nothing, I though Philco stamped all there transformers, I might be mistaken though. Thanks
Jon
No marking on mine either. Also, none on the filter choke.
Good, thanks for checking, they are original then, I'm glad to hear that.
A belated welcome, Jon! And congratulations on your acquisition of one of Philco's neatest consoles. When you have it all finished, you'll like how the grille area lights up when the set is on (assuming you install a new appliance bulb in place).
As Bob (bandersen) told you previously, the original power transformer was vertical mounting, part no. 6672. Here are the specs:
Primary 110-115 volts, 60 cycle AC
High Voltage Secondary: 720 VCT @ 145 mA DC
Filaments: 6.3VCT @ 5 A
Rectifier Filament: 5V @ 2A
If you can't find an original, a Hammond 274BX will work - be aware that its B+ (high voltage) is somewhat higher at 750 VCT but this will translate to roughly 15 volts more B+. This can be left alone, or compensated for with a dropping resistor. The 5V and 6.3V windings have higher current capability (always a good thing), but note that the 5V winding in the Hammond has a center tap which will be unused and will need to be carefully taped off.
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
There are currently 642 online users. [Complete List]
» 1 Member(s) | 641 Guest(s)
