My tallest Philco console
Well, let's hope no one plugged the wrong plug into the AC outlet.
BZZZZZZZZZZZZZZZZTT!!! There goes the antenna coil.
Good luck!
just confirming Ron' quote above about fewer radios. My theory is based on our total lack of basements. Things just go in the trash because there is no place to store them. I never saw a basement until I was 48 and visited Michigan. Out here we have an aversion to being in a room under the house when the next earthquake comes.
Keep one hand in your pocket
Quote:BZZZZZZZZZZZZZZZZTT!!! There goes the antenna coil.
Maybe that's what happened. On the antenna coil, the outside coil seems OK, but the lower inside coil is open. Also, the 20 ohm, wire wound resistor mounted on the coil is burned away. I have contacted Ron.
DK - email answered. Icon_smile
Arran. As always, the information you have provided is very valuable to me. Thank you. Yes, it is a Canadian Philco 316A...RadioSvit — 04:04 PM
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM
There are currently 988 online users. [Complete List]
» 3 Member(s) | 985 Guest(s)
