A National NC-183D
What is it and how expensive should it be? OK, I have learned that it is a model NC-183D not 1830.I have seen one and it is definately different looking. Has a speaker in a metal box. It has a pretty high price tag on it; $275. Anyone familiar with this type of set?
Are they nasty to work on?
Well it's not a "radio" so maybe it doesn't count.....it's more like a boat anchorIcon_biggrin
OK fixed the typo. Get a little dyslexic every now and then.
Gene
Really don't know much about the radio. They're supposed to be good receivers from what I've heard but I have no experience with them. I've seen them, one at a hamfest in Wyoming, MI. Forget the price but seemed awfully high as it wasn't in very good condition. $275, to me, doesn't seem unreasonable it it's in nice shape.
Mike
I'm thinking you mean a NC-183D?? I have a '173 and it's good little set. The '183D is a double conversion job so the alignment on it maybe a little tricky. All of that series are great sounding radios '173,'183,'183D. The '173 wasn't hard to work on at all.
It might be worth a little more if it has a matching National brand speaker with it but I think you could do better then $275, for an unrestored one. Aside from old Hams and radio collectors not many people have an interest in boatanchor sets.
Fortunately, it does have the metal speaker with it. UNfortunately, the condition leaves a lot to be desired. I am going to try and check it out further and see what the chassis looks like. I have also learned I need to check the transformer as these evidently had a habit of frying themselves.
Gene
The condition of the set or the condition of the matching speaker leaves a lot to be desired? A cosmetically beat up and unrestored set shouldn't be anywhere near $275, probably not even 1/2 that amount. I'm not up on the going rates on boatanchors but I have noticed that when it comes to brands the Hallicrafters equivalent model of a given National model is generally more collectable. Whenever I hear of anyone chasing after a National model it's usually one of their HRO models.
About the transformer if I remember the original design called for a couple of paper caps from each side of the HV winding to the chassis. That's what kills the power transformer...
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
