50L6GTtube normally run 170 degrees?
Hi.. I have just finished my first attempt at restoring a Philco PT92. After replacing the capacitors, it fired up (used my newly built dim bulb tester). It picks up stations, but i noticed the 50L6 tube gets very hot. I measured it at 172 degrees. The other tubes are warm, but not too hot to touch. I had an old spare I put in, and it gets hot to. (same temp)
So, what is the normal temp of this tube. By the way , I played the radio over 2 hours, and everything else seemed OK.
Any comments or ideas on this,
thanks, buzz
Hello, Buzz: I have never measured the temperature of my tubes, but I will say that output tubes like your 50L6 and rectifier tubes both tend to run very hot, as in hot enough to burn you if you touch them.
If the set exhibits no other problems besides trying to shock you (like all AC/DC sets try to do to me), I would not worry about it!
Ok TA , i wont worry about it. thanks
The 2 towns you mentioned "Frustrated" and "Give Up" are places we have all been. Relax, take 5, thi...Paul Philco322 — 03:23 PM
Philco 89 Code 123 Osc Coil
Thanks for posting that information!klondike98 — 03:14 PM
From what I see is the blue cap was added by someone after the radio was sold presumably to replace cap 40A. I can't tel...RodB — 03:12 PM
Correction My original picture shows #40 cap, blue cap and #42 resistor connected.osanders0311 — 02:23 PM
Well guys I am stuck, frustrated and about ready to give up. For starters all I'm getting from the speaker is a humming ...osanders0311 — 02:17 PM
[split] New member...
Thanks.  I'll try that.HowardWoodard — 01:13 PM
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
There are currently 1018 online users. [Complete List]
» 4 Member(s) | 1014 Guest(s)
AvatarAvatarAvatarAvatar
